Cannot make/receive calls on 3G even though it shows signal
I have received a xperia phone (Xperia XA1 G3121) with following problem which I want to try and resolve: While having a SIM I can make calls and have mobile data as long as I have 4G or H+ indicator on the top right corner.
In areas where those are unavailable (I get 3G and bars indicator) I cannot make calls nor have mobile data connection.
While searching the internet I came to find videos about replacing antenna cables. After removing the back I found 2 such cables (black and white):
I replaced the cables thinking that might solve the problem without any success. In youtube videos I saw variant with only 1 cable and 2 cables. My intuition was that the black one is for 3G since disconnecting the other disabled my 4G signal. Given that on some networks I have data and tone and on older generation frequencies I don't I came here seeking some advice. What can I try to isolate the problem?
Later Edit:
I have replaced the bottom daughterboard earlier because another defect with it was that it would not charge. At that point I did not try 3G or below calls because I couldn’t imagine not working after doing a normal call as a test. The previous daughterboard was thrown as a results. Should I suspect a flaw with the new daughetboard ? Any way to check it other than trying another replacement ?
Any help you can shed is appreciated, thank-you
Es esta una buena pregunta?
