Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lanzado en febrero de 2018. Dell Inspiron 14-5482 presenta una pantalla HD de 14.0" y núcleo Intel i7.
Charger needs to be put in a few times or rotated a bit to work.
Charger needs to be put in a few times or rotated a bit to work. Any idea why this may occur or how to fix it? Nothing appears wrong with the charger or port, but there is obviously an issue somewhere.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Start with a new GENUINE power adapter and see if that resolves the issue first - a lot of the time, it’s just a bad charger. If that doesn’t fix it, you’ll need to replace the power jack.
On many of these newer Insprion models, the procedure to change the power jack is easy enough if you’re comfortable inside a computer, you can do it yourself. You can find the part here, and the service manual here.
Just a few years ago before Haswell, it was a crapshoot - some were easy, others were okay and some were awful. The new ones are a 15-20 minute job for anyone who knows what they’re doing, while they could be a genuine nightmare on many of the older ones - even IF you know how.
Fue útil esta respuesta?
Puntuación 3
Clean the connectors using a pure alcohol and a Q-Tip.
Puntuación 1
Añadir tu respuesta
TYLER GOODWIN estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 351
