Phone has a pink shade on 3/4 of the screen?
How can I fix this issue?
Es esta una buena pregunta?
Rinku Master this sounds like a bad display since it is only showing on parts of it. Most likely will require a new display assembly. Reemplazo del ensamblaje de pantalla del Samsung Galaxy Note9
Fue útil esta respuesta?
Hi,
Just to add to the answer above, try starting the tablet in safe mode just to eliminate the remote possibility that it is a software problem that is the cause of the problem.
If it also display the same when in safe mode try a screen replacement as suggested above.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 743
