there is an audible click at roughly 2 sec interval
I have a kitchenaid KRMF7065ESS01
It has been operating intermittently for a while. there is an audible click at roughly 2 sec interval from time to time when it is not working. When it is doing this, nothing is working, not the lights, not the door water/ice, etc. I can sometimes get it back by power cycling w the breaker, but seems to be having these episodes one or twice a week for several hours. The unit is 3 years old. Help me.....
Es esta una buena pregunta?
4 comentarios
I will do this this weekend, but the compressor stops cooling and there is tha audible clicking, and yes the control lights still work work but no ice or water is dispersed
Feedback welcome,
Coils, back and front clean. cleaned everything thinking this was the issue based on post here but issue persists
- de Grant
Mine is doing the exact same thing as grants and it’s the same model. When the lights go out in the fridge and the ice/water stop working, the control panel still lights up. Mine also stops cooling and when I unplug it and plug it back in you hear click and then it start back up. Help Please!
- de tiffymuzzey
tiffymuzzey & grant, the light switch could be the problem. There might be two switches for each door. One you will see around the opening. The others might be under the hinge covers at the top. Unplug the unit and check the connectors. Make sure they aren’t loose. You should use a multimeter set for ohms and check the ohms on each switch. The door switches operate the lights and ice/water dispenser.
- de LadyTech
Mine is Kitchenaid krmf706 it will stop dispensing ice or water, though the dispensing control lights work but the lights go out inside It starts making noises like it is sending Morse Code to someone. I can reset power and after a minute or so it will reset but I have got to find a permanent cure for this.
- de eagle1980
