Saltar al contenido principal
The LG Stylo 4 is a stylus-equipped midrange slate-format Android smartphone released by LG in 2018. Identifiable by model numbers L713DL and Q710(AL, CS, MS, TS, ULM, ULS, and US).
Wont charge past 2% tred differet cords
My phone will not charge past 2% is there any guids that can help me fix it? I had it for 2 years dont want to pay $80 to take it to the shop
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
@chefnoyes start off with a new battery. After that you will need to check the charging port. If that is okay you will need to check the components on the circuit board. One suspect would be a bad power management IC but there are plenty more suspects. I would replace the charging port flex since that would eliminate most other suspects. You can get a replacement at places like this Once you replaced the battery and find you have to disassemble your phone post plenty of pictures with your QUESTION so we can see what you see. This video will at least get you into the phone.
Agregar imágenes a una pregunta existente
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
joe estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 4
Todo El Tiempo: 243
