Saltar al contenido principal
La TI-84 Plus CE es una calculadora gráfica lanzada en la primavera de 2015 por Texas Instruments. Incluye una pantalla a color de 2,8 pulgadas, puerto USB, aplicaciones, almacenamiento y una batería de 1200 mAh.
Preguntas 84 Ver todo
Water went into the calculator
My water bottle broke and I didnt realise. So my calculator was sunk in water for more then 30 mins. Then I took it and dried it in the sun after removing the battery. When i on it again, all the buttons were working but when i offed the calculator, the screen did not go black like it should and it was a dimmed white screen. Then after 2 days, when i on it again, the top bar started fading and was in green colour, then when i typed anything it was fading. Then in 2 seconds it would go back to normal.
Pls help me I really need this calculator to do my exams!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi,
The calculator will need to be opened and inspected as to what damage has occurred.
Water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the calculator’s operating design and could damage the components. The corrosion starts immediately and is ongoing until it has been properly cleaned away
First do not try to charge or to turn on your calculator and then remove the battery as soon as possible from the calculator to minimize any further damage.
Then you need to dis-assemble the rest of the calculator and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do use it, check the label to verify the amount of IPA. The higher the concentration (%) of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Also remove any shields that may be covering some components as there may be corrosion under them as well.
The LCD screen connections to the motherboard may need to be checked to ensure that there is no corrosion between the leads as well.
Hopefully after you have done all this the calculator might possibly work correctly again.
Here is a teardown video of the calculator, which may help.
If this process seems too daunting, take your calculator to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later. It isn’t going to fix itself.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Depending how new the calculator is, this iFixit teardown may look more similar to the internals of the calculator. TI-84 Plus CE Teardown
- de
Añadir tu respuesta
Nagaraj Yohapriya estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 58
Todo El Tiempo: 1,183
