Repairing power connection , intrenal
When power cord is connected,no power ,green light does not go on.
Is there an easy fix to this or must I re solder ,on interior of book.
Es esta una buena pregunta?
IIRC that model had known problems with the battery and the power connector. Check the cord with a multimeter to be sure its providing voltage to the computer. If it is you will need to check out and quite likely need to repair or replace the power connector. I am including a link to the guide that comes closest to assisting you with disassembly. Good luck.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 784
