Introducción
This guide will take you through the steps necessary to disassemble your Powerbook 5300, reach its hard drive, and replace it.
Herramientas
Partes
No se especificaron partes.
Position the Powerbook towards you with the monitor closed.
Press the battery removal latch located on the right side of the front panel.
Gently slide the battery out.
Turn the laptop over and remove the three T8 torx screws from the bottom panel.
Gently lift up the laptop's front-most panel and slowly raise the trackpad from the logic board.
Disconnect the front panel's ribbon cable from the board by slowly pulling it out of the connection port. Set the panel aside.
2 personas más completaron esta guía.
