Saltar al contenido principal
Repair information for the Samsung 55" Smart TV with model number UA55JS8000 or UA55JS8000W.
Preguntas 7 Ver todo
Screen issues, pictures and description attached.
When I power on my Samsung LED i get these screen issues the bars stay in same location but can have some flicker in them.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@helpwithsamsung could be a bad main board (most likely) or a bad T-con board. Worst case scenario it s bad LCD driver board (unlikely). I would start by replacing the main board. Get it from a place that has a decent return policy (or a cheap used one) so you can return it if it does not resolve your issue. OF course, check all the ribbon cables and make sure they are properly seated etc. Specifically the ones on the T-con and main board. Always check for obviously damaged components as well. You can always post some pictures of what you find with your QUESTION. That way we can see what you see.Agregar imágenes a una pregunta existente
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Deni Carter estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 497
