Saltar al contenido principal
El HP Envy dv7t-7200 es un portátil completo con un panel táctil como parte de la serie Envy dv7, lanzado al mercado en 2012.
Preguntas 3 Ver todo
How do I remove the bezel from the display?
How do I remove the bezel and trim around the display? I already have it removed from the notebook. I just need to get to the inverter underneath to test it. There appears to be a screw under the bezel near the hinges on each side holding it in place, but I cannot seem to get to them. I know if I apply any more pressure I’ll break it. I’ve already used a heat gun and I know it’s not glued on. Thank you.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi,
Here’s the maintenance and service guide for the laptop, taken from this webpage.
Go to p.93 to view the procedure to remove the bezel from the display assembly.
Hopefully this may be of some help.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
Thank you! Yes, I assumed the Beats Audio speaker grill was removable, but since it could not be popped through from the inside I needed to make sure before using a sharper spudger to remove it. I appreciate the timely response!
- de
Añadir tu respuesta
chazdevereaux estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 126
