Audio output only on one side
My Google Pixel audio balance is set right in the middle but there’s only sound in the left earbud. This is true for bluetooth earbuds and wired earbuds, playing content from various apps. I thought my right bluetooth earbud had suddenly gone bad so bought another pair, but same issue . Any ideas?
Es esta una buena pregunta?
3 comentarios
So what happens when you set balance only to the right? no sound at all?
- de V@no
Changing the balance only to the right is the same volume on the left as having it all the way to the left. In the middle, it's loudest on the left.
Google help desk had me take the phone out of the case which oddly made the right earbud work on wired headphones, but the right is still not working on bluetooth. They told me to use the nuclear option, factory reset. Ugh.
- de Cynthia Replogle
I contacted Google support and they had me try the steps below, but the problem persists.
Please follow the below steps to resolve the issue
Step 1: Turn on Safe Mode & fix apps
Some apps that you download can cause issues with your phone. This can include audio apps and apps that run audio accessories.
Learn how to find and remove problem apps with Safe Mode. https://support.google.com/pixelphone/an...
Step 2: Turn off Switch Access
While in Safe Mode, turn your volume all the way up. If your volume buttons don’t work, open your Settings app and tap Accessibility. If Switch Access is on, turn it off.
Step 3: Reset to factory settings
Important: If you can, back up first. Any data that’s not backed up to your Google Account or another service will be lost.
Learn how to back up your personal data. https://support.google.com/pixelphone/an...
Learn how to reset your phone. https://support.google.com/pixelphone/an...
