Saltar al contenido principal
Modelo A1237 o A1304 / 1.6, procesador 1.8, 1.86 o 2.13 GHz Core 2 Duo
Not powering on with charged battery
MacBook air 2008 not turning on on battery power but turns on with charger cable battery indicator shows fully charged, have done smc reset no change. Powers on and off on charge cable, remove cable dies instantly.
Update (08/06/2020)
Could not run coconut battery on lion so tried this one not sure how accurate it is.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Lets get a better idea on things here' Install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Agregar imágenes a una pregunta existente.
- de
Agregar un comentario
1 Respuesta
Wow! A battery thats gotten to 5911 cycles!
I think you really need a new battery! A batteries lifespan is about 1000, I think you pushed it a bit ;-}
Determine battery cycle count for Mac notebooks
Here’s the needed part MacBook Air (Original-Mid 2009) Battery and here’s the guide to put it in Reemplazo de la batería de la MacBook Air Modelos A1237 y A1304
Imagen de Replace the 5560 mAh battery compatible with MacBook Air (Original-Mid 2009). 40 Watt Hours (Wh), 7.2 Volts (V).
Producto
$29.99
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Ha yes I don't think that was quite right I'm just going to order a new battery and see what happens.
- de
Añadir tu respuesta
Aaron S estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 95
