Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El HTC 7 Surround es un smartphone creado por HTC que funciona con el sistema operativo Windows Phone.
screen wount go past htc load screen hwat should I do
i had the phone on one day but it was messing up and wouldn't show my pictures so i turned it off and back on and i wont go past the htc screen. i called at&t and htc for help but thaty said its nothing they can do since i brought the phone on ebay. i hadn't even had it for a month yet an im inlove wit the phone plz help!!!!!
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
3 Respuestas
Solución Elegida
Thanks for posting your problem. I have just fixed this problem on a customer's Phone. You will need to replace the MicroSDHC card in your Phone. You will need to take apart the phone, at least partways, to do this. Here are the parts needed:
Torx 5 Screwdriver
00 Phillips Screwdriver
16GB MicroSDHC Memory Card (found here: http://goo.gl/6urM7)
As a note, the card in the Phone I was fixing was a Class 4.
You should be able to use this video as a guide to take apart the phone to where you can replace the MicroSDHC Card: (http://goo.gl/sJ5h0)
Best of Luck,
Tough Gaming Technical Support
Agent Elisha
Fue útil esta respuesta?
Puntuación 3
1 comentario:
+ Thanks for your help Elisha. Your help around here would be very much appreciated ;-)
- de
Unfortunately AT&T or HTC won't help being that this item was purchased as is/used and most likely is damaged. I would try to Hard Reset the HTC and see if that helps. If not, check back here for further troubleshooting.
Puntuación 2
SD internal replacement.you also can use 32g card. (Standard sd card)
Puntuación 0
Añadir tu respuesta
jalisa estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 23
Todo El Tiempo: 2,022
