Sound No Video. Half works if one ribbon from T con removed.
I have Samsung 50" LED TV that goes dark if both ribbon cable coming out of the T-con board is connected, but half side works (with white the other side) if I remove one of the ribbon cable. I’ve tried replacing T-con board and mother board. Nothing wrong with cable (I can switch cables and same result). Does this mean the panel is bad on one side? why does the whole screen go dark when I connect the bad side? Any input is appreciated.
Es esta una buena pregunta?
what if your model tv doesn’t have a separate icon board where would it be located then. I have a Samsung 40h5003af tv and it had picture that I could see using a flashlight so I changed the lens and now I have no picture. I changed the power supply board and the main board already
- de Mike Cardone
