Guide usable on a regular T460, non S?
Hello, I am wondering if the guides are mostly interchangeable between the T460S model and the standard T460. I’d like to fix mine up a bit.
Es esta una buena pregunta?
Hi @chromalife ,
Here’s the hardware maintenance manual for the Lenovo T460.
It details the necessary pre-requisite steps and procedures to remove/replace all the components in the laptop
If you need any parts, here’s the parts list for the laptop.
Type Thinkpad T460 in the search box and then select the appropriate model variant. The parts list will open and then under Commodity select the component that you want, and then scroll down to find the part number of the component.
Search online using the part number only in the search term of your browser, to find suppliers of the part.
Hopefully this is of some help.
Fue útil esta respuesta?
I checked this out and found that the internal layout of components is different between the T460 and T460s models. So while there may be some similarities, it is not exact.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 321
