Is there som guide to how I repair my charging port?
my charging port is lose.
Es esta una buena pregunta?
Hi @mrgiltoft
Here’s the maintenance and service guide for the laptop.
Go to p.5-55 to view the necessary pre-requisite steps and then the procedure to remove/replace the USB/Power connector board.
If it is loose you may be able to solder it back on.
If not then at the top of p.5-55 there are the part numbers for the two boards available, depending on what charging adapter that you have. The adapter’s output Wattage should be printed on the adapter.
Search online using the appropriate to your adapter’s part number only in the search term of your browser, to find suppliers of the connector board that suit you.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 77
