Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
Lanzado el 22 de noviembre de 2005, el mando inalámbrico de Xbox 360 es el mando de juego principal para la consola de juegos de Microsoft Xbox 360.
Spilled Juice On Xbox 360
Spilled juice on the controller. It was working at first but then the lights on where the x is at in the middle of the controller faded and it just died so now the juice is dried and I don`t know what to do
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
4 Respuestas
Solución Elegida
this guide will help you to get to the internal parts. Use this guide to help you clean it out. Orange juice has citric acid in it and will be gobbling away at all the parts. I'd check out the battery pack too..make sure your batteries aren't bulging/leaking etc, make sure the contacts are clean etc.
Fue útil esta respuesta?
Puntuación 5
1 comentario:
I'm 10 but my controller got put in the washer and the light turned no but it will not work on the tv. What do I do?
- de Compartir
i spilt juice on my xbox 360 controller and i left it for about 7 or 9 months and i dont know what to do can some one help. but some one told me to dip it in water then dry it but im not shure pls pls pleassssssssssssssssssssssss help some one
Puntuación 0
3 comentarios:
stewie, did you check the two guides that are listed in the above answer? Those will show you how to clean it.
- de Compartir
unscrew the cover and place it in a fixed clean controller and leave the black parts of the bottom old controller out and get the new one and rescrew it in to the fixed one! hope this awnser helps you! :)
- de Compartir
I need help .y mom had my controller and said some how water got in it but I cleaned it out and it worked for a while but now it doesn't
- de Compartir
If it is dry, then unscrew it and check which part it dried on
Then, remove the part carefully and scrape the juice off very carefully with a tooth pick
Puntuación 0
3 comentarios:
Ryan Ckit, and how to clean the corrosion caused by the citric acid?
- de Compartir
Never thought about that
- de Compartir
It is great to see that you are really trying to answer and to help out. Welcome to ifixit:-) What is important is, that you think about every aspect of your answers. A lot of folks on here are looking for viable answers to repair their equipment, and will judge your credibility by the answers you provide.
- de Compartir
bit late still dont worry its simple as potato , frist disassemble it as shown in first link where useful and just clen it up all cricut board and then make it dry and reassemble it agine whole u done the controller new even i felt my controller bit clean after this
Puntuación 0
Añadir tu respuesta
Donta estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 11,457
