Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Support and repair information for Marantz home theater AV receivers and older audio-only receivers.
How to replace the bleu led light on a Marantz SR-7005?
On my Marantz there is a blue circle that lid up when the amp is on, but it look like only one is still working. I was wondering if it’s possible to tix it?
Any clue as how to do that.
sincerely Marc
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @mdehand ,
Where is the blue light located?
In the service manual there is no mention of a blue light. There is only a red LED and a green LED mentioned.
Update (05/24/2020)
Hi @mdehand ,
The display unit has two fluorescent tubes inside it but no mention of their colour so I’m assuming that this is where you mean. If one of them is not working it could either be the tube itself or a fault in the power supply circuit to that tube e.g. faulty connection or component.
The supplier in the link is the only one that I could find. You may have better luck. Hopefully it is just a faulty connection or component in the power supply path as the tubes are not cheap.
Here’s an image taken from p.129 of the service manual showing the power supply circuit for the tubes.
Imagen
(click on image to enlarge for better viewing)
Fue útil esta respuesta?
Puntuación 3
3 comentarios:
If you look at the face of the amp there is a center display and around it there is a bleu light.
- de
Thank you for your help and you fast answer, I will look at it, now that we pinpoint the location and see if I can do this. thanks again.
- de
Press and hold DIMMER on the main unit for 3 seconds.
Carry out the same procedure if you want to change the settings again.
- de
Añadir tu respuesta
mdehand estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 899
