Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Modelo A1059 o A1099 / disco duro de 20, 40 o 60 GB / rueda de clic sensible al tacto
Why doesn't it work when unplugged?
It works when plugged into pc. It shows a full charge but doesn't turn on when unplugged. What is wrong? How can I fix it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
7 Respuestas
Respuesta Más Útil
Sounds like replacing the battery would solve the problem.
Fue útil esta respuesta?
Puntuación 3
I had a very similar problem. The charge on my 4th Gen Photo battery would last less than 30 min. before completely depleted. In addition, I would plug in the firewire charger into a wall outlet noting that the date and time would reset to Jan 01, 2000 0000hrs. I did not lose any on my tunes. Thus I only listened to it if I was able to plug in in to an outlet somewhere.
After seeing the replace battery suggestion noted above, I did just that. I disassembled my iPod and discovered that the battery within was bulging from the center --- (I had a similar problem with a cell phone battery that fail to maintain a charge) --- swapped out the batteries, charged it up and have not had a problem since. With the proper tools I had purchased here at iFixit (yes, you need the spudger to remove the old battery), my total repair time was less than one hour.
Puntuación 0
hi, mi I pod got stuck on one song and it will not turn off or change to any tracks, what could be wrong
Puntuación 0
1 comentario:
please start a new post- just ask a question :)
- de
Have you tried a soft reset first to get back to the startup screen?
Puntuación 0
My iPod will turn on if plugged into the Bose Dock player but will not if held in hand
Puntuación 0
After charging with PC USB it got stuck with eject option. But nothing is happening with My Apple IPOD just showing msg eject before remove.
Please help
Puntuación 0
tell me what i cant do
Puntuación 0
Añadir tu respuesta
cindy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 19
Todo El Tiempo: 3,628
