Battery replacement for fugoo xl tough
Where can I purchase a replacement battery for a fugoo xl tough please.
I am in Australia
Es esta una buena pregunta?
I am in Australia
Hi,
Don’t know the answer but if you disassemble the speaker to get to the battery there may be a battery model number printed on the battery.
By searching online using the battery model number only in the search term of your browser you may find suitable suppliers.
If there is no model number on the battery, it may have other relevant information that you might be able to use such as voltage (V), capacity (mAH), dimensions and possibly type of battery i.e. LiPo (Lithium Polymer) or Li-On (Lithium Iron) to find a suitable replacement.
With dimensions for LiPo and Li-On batteries, it is usually just a 6 digit number. The convention is that the first two digits are the height (or depth) of the battery in mm with a decimal point between the two digits that is not shown, the next two digits are the width in mm and the last two digits are the length in mm e.g. 507090 = 5.0mm H x 70mm W x 90mm L.
A search example could then be 507090 (insert V) (insert mAH) LiPo (or Li-On) battery.
You may not find an exact match so then you have to try to find something that is close. The important value is the Voltage. It has to be exactly the same. The dimensions are also important as the battery has to physically fit into the device. The capacity (mAH) is of less importance. Obviously you would want the same capacity or better so that the speaker has the same or longer playing time before needing to be recharged.
Here’s the ifixit Fugoo Tough XL Battery Replacement guide that may be of some help.
Hopefully a start.
Fue útil esta respuesta?
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 140
