Bottom Mic very quite?
I have a customers iPhone XR and he says the bottom mic is very quite on speaker phone. Would I just have it replace the charging port to fix this issue?
Es esta una buena pregunta?
I would first clean out the grills at the bottom of the phone. You can either use compressed air, a toothbrush, or a pair of fine tipped tweezers.
If you end up having to replace the charge port, make sure you use an OEM one. The X and above are picky when it comes to charge ports and they don’t like the aftermarket ones.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 162
