Saltar al contenido principal
Un portátil de clase empresarial fabricado por HP en 2014. Número de modelo: M0X64US # ABA
Preguntas 4 Ver todo
Laptop not switching on with battery sometimes
My laptop switch on when connected to power. If you don't use it for about 5 days, it can switch on on battery. When it's in power, it does not charge the battery more than 76%.
So sometime it works on battery and sometimes it doesn't. What could be the problem
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Do you know if the battery is original? This was released 6 years ago and most PC batteries last 2-3/4 years.
If you can get it to start without the battery, one of the cells is bad. Refer to this guide to disconnect it and see - that should be sufficient for troubleshooting unless it has to come out due to it’s design.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Thank you for your quick response.
I bought this pc from ebay UK.
I ordered a brand new battery after this problem started. But the problem is still there
- de
Añadir tu respuesta
Kumbirayi Chitauro estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 210
