Saltar al contenido principal
HP zBook 15u G3 es un portátil 2016. Muchos usuarios pueden tener la necesidad de expandir su almacenamiento, reemplazar algunos componentes y hacer algún mantenimiento. Tenemos la intención de proporcionar algunas guías en este dispositivo.
Plugged in not charging
i have tried 3 chargers now, but it stil won’t charge.
what can be the problem here?
Es esta una buena pregunta?
Puntuación 0
3 comentarios
Hi @sidern ,
Does the battery light on the side of the laptop turn on when you connect the charger to the laptop, you didn't say?
If so what colour is it?
- de
How do you know it’s not charging? Does it turn on/boot up normally?
- de
yes it turns on and boot into windows, battery icon chows 0% plugged in, not charging.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
hi @sidern,
You may have a faulty battery.
Create a Win 10 battery report to check on the condition of the battery.
If it is determined that the battery needs replacing here’s the maintenance and service guide for the laptop.
Go to p.40 to view the necessary pre-requisite steps and then the procedure to remove/replace the battery.
Also at the top of p.40 you will find the part number for the battery. If you search online using the part number only in the search term of your browser, you’ll get results for suppliers of the battery
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
tor_arne_ovrum estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 6,172
