Honda Harmony 215 Lawn Mower Service Manual?
Hi, I have the lawn mower referenced in the title. Maybe someone on here has or knows where to find the service manual for it. It is a self-propelled, 21", mulching mower. It has trouble with high grass, by high I mean about 7" tall. The deck is set at the 2nd highest setting it can be set to. It cuts the grass fine for about 4' then won't cut it at all. If you disengage the blades, then re-engage them it is good for another 4'. The blades are sharp, installed correctly. There is no center nut/bolt holding the blades, on this model. There are 2 bolts holding the blades to what in appearance is more than likely a centrifugal clutch assembly. Any useful help on this would be greatly appreciated and rewarded by ifixit points. Thank you for taking the time to read this.
Es esta una buena pregunta?
2 comentarios
how do you replace a starter rope on a honda harmony 216 gas powered engine?
- de KATSUHISA NISHI
Drain the gas out of the tank using a model airplane transfer pump.
Undo any snap or clip fasteners and remove any screws holding it together. Be sure to wear safety glasses in case anything snaps loose. Save any screws or loose parts for re-assembly
Take the recoil assembly to your local mower supply shop and show it to the counter guy.
Tell him you need the parts to make it work.
He'll give you the rest of the info you need.
Alfred Schrader 8/2016
- de alfredschrader
