Saltar al contenido principal
Lanzado en abril de 2019. Número de modelo: A705FN / DS
My Phone does not charge when connected
My phone does not charge when connected to the charger.
Charger works on another Samsung phone but does not on mine.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 15
5 comentarios
I had this happen to my A70. I replaced the USB-C port but it still wouldn't charge.
I read later that it's a failure in the chip that controls charging and saw a video where a guy soldered a thin wire from the chip directly to the USB-C port and it started charging again.
I have up after that cause there's no one in my area that does micro soldering and that's just not in my wheel-house.
- de
Really it worked for me too...
Thanks guys 🤩 A big thumbs up👍
- de
I have same issue. After changing charging board and flex cable it charging again but not superfast charging, just stated fast charging or only charging. I think i bought not oem board. Maybe...
- de
Anche io ho avuto questo problema e ho aperto di nuovo e ho trovato il problema il flex si è staccato.
- de
This really worked for me as well. I pressed from back as mentioned and it started charging. 👍👍👍
- de
Agregar un comentario
13 Respuestas
Respuesta Más Útil
In a very weird way I got the same issue and fixed it by pressing hard on back of phone a bit higher & lower than samsung label!
I read it somewhere in the net, and I could not believe it would work!
And it seemed like the charge was being done & only not seen by eye…
pretty weird!
Fue útil esta respuesta?
Puntuación 32
21 comentarios:
Only thing that worked for me! Thanks
PS: is it still working now?
- de
I just logged in to tell you you're a life saver. I never thought something this simple could wok. My phone es now charging perfectly!! Thank you SO much!
- de
thanks it worked for me!
- de
I have no idea how, but that works!!
For real, My phone has a a half a millimeter space between the back cover and the battery(it presses when I press harder) and I did that a quit harder a couple of times and the phone started charging.
- de
It worked for me too...thank you
- de
Mostrar 16 comentarios más
***Replacing Motherboard Connection Flex Cable worked for me solving this problemin more than 10 phones.
Puntuación 4
4 comentarios:
So I got my charging issue fixed by just pressing hard on the back of my phone and this seems to be the issue I guess.
- de
If i rplace the Motherboard Connection Flex Cable will it fix the problem of charging ?
- de
@Art avdiu possibly but it depends on what causes the issue. Start with the flex cable and see what happens.
- de
Great simple solution no need for a specialist
- de
https://okadtech.com/samsung-a70-not-cha... This can help you.
I was also facing the issue by through the article I came to know about reboot and this trick worked for me.
Puntuación 1
I recently had this happen to my Nexus 6, so i can tell you a lot about what to look at.
First thing to do is to reset the Power Chip. This process takes a while. First, run the battery down all the way, until the phone turns off. Then keep turning it on until it will not even start to boot (no lights, black screen). Let it sit that way for an hour or so. Then try to charge it. The only way to reset the Power Controller Chip is to completely drain the battery. I have had this fix one of my android phones which was not taking a charge via the Micro USB port. If the phone starts to take a charge, charge it up all the way and then shutdown (power off), wait a few minutes, and turn the phone on again. Completely draining the battery can leave some of the hardware in a bad state, but a power cycle should fix that.
Is your phone a Samsung A70? Or am I seeing an ad for the A70 on this web page? If you have an A70, you do not have built-in wireless charging (Qi).
If your phone is Qi capable, then get (or borrow) a Qi wireless charger. Ignore this bit if your phone is an A70. If the phone takes a charge via Qi, then you can use that to charge it until you get a new jack installed. There are Qi chargers for sale at Target for $10, up front near the registers, in the “$10 or less” section.
For my phone, replacing the micro USB jack is $100 parts and $100+ for labor. The micro USB or USB-C jack is the first thing to be installed into the phone case when it is being assembled, and the last thing to come out when it is being disassembled for repairs, so the labor charges for replacing it are high.
Puntuación 0
i had the same issue and after a lot of tries to replace the charger or the cable , i go to customer service and they told me after checking it that the problem in the charging chip and exactly in the IC of charge and they don’t have the IC but they have the chip of charging and after they replace it the charging works correctly but after 5 months the issue come back again and after checking the mobile again by the customer service they told me that the IC damaged again and they replace it again but the phone did’t work this time and by checking again by customer service they told me that the port of charge cable in the mother board is broken and they did’t have replace parts to it and my phone is still broken until now , and by searching internet about samsung galaxy A70 reviews , i found that a lot of customers have a lot of issues of this phone because of the poor and bad material that the company made the phone from
Puntuación 0
The power comes on the mini board but on the mani board he have no power
Puntuación 0
I have had this problem on my Sam A70 over a few months and have read numerous, restart, clean the contacts, change the charger articles... Then one said turn the phone over and press quite hard 1/2 an inch above the Samsung logo. To my amazement it worked - again just a few moments ago. I don't know why. It may reseat the battery, move contacts slightly to clean them? At least it moved me forward, allowed me to keep the phone - and this may help in a permanent solution...?
Puntuación 0
My samsung doesn't charge because of a little metal that is broken on the motherboard, where you put the flex cable that makes the connection from the charging board to the motherboard.
If I put some solder on this small area, will the phone charge again?
Puntuación 0
Yessssss it does the job pretty well press a bit harder above an inch of samsung logo and it'll start charging idk why how but it does...1000%
Puntuación 0
1 comentario:
Will you lose the data if u do that? I mean if u press the back
- de
This will help you just go and solve your problem.
Try that force reboot in my case it worked for me.
Puntuación 0
yes cant able to charge my mobile charger portal is problem
Puntuación 0
Its better you change the downpanel also known as sub panel.
Puntuación 0
لا يشحن ولا على اي شاحن
Puntuación 0
Añadir tu respuesta
Kenneth estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 28
Ultimos 30 días: 112
Todo El Tiempo: 15,531
