Saltar al contenido principal
The HTC Vive controller can be identified by its model number: 2PR7100. It is a first generation motion controller released by HTC on April 5th, 2016 as an accessory part of the Vive Virtual Reality set.
Preguntas 16 Ver todo
Is there any way I could buy a replacement track pad?
Okay so, I found out specifically that on one of my controllers the haptic feedback and sound is not working. The reason why is because there is a thin ribbon cable that tends to brake inside the controller, as seen here that causes the feedback and sound to not work. I was wondering if anyone knows where I could purchase a replacement trackpad. Please and Thank you.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
The only thing I have found is on ebay, there currently is this listing up for bids and a listing for a lot of 5 that don't click. should be able to harvest the touchpad or repair one.
https://www.ebay.com/itm/HTC-Vive-Contro...
https://www.ebay.com/itm/LOT-OF-5-DEFECT...
- de
Agregar un comentario
1 Respuesta
Also apparently the steam controller uses a near identical track pad if you can buy a donor steam controller cheaper then a donor vive wand give that a try.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Unfortunately the trackpad in the controller has a plastic assembly welded to it to turn it into a moveable button so a steam controller would not work.
- de
Añadir tu respuesta
Jake Gardner estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 878
