Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Kenmore 110 Series es una lavadora para el hogar de fácil uso creada por Kenmore.
Overflows when draining. But only for the first few seconds
kenmore 110. We’ve had the washer in our home for way over 10 years.
What is happening is that when the water drains the initial push of water into the drain pipe overflows it. After the first few seconds it stops doing it. Washer is next to an outside wall with the cleanout just outside. We have verified that the drain pipe and swewer pipe is clear (again just during the initial draining it overflows.
It’s like the drain pipe needs to be primed or something. Once flowing its ok.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
If your Kenmore 110 Series Washing Machine is not draining after a wash cycle, see the Kenmore 110 Series Washing Machine Won’t Drain problem page for possible causes and solutions.
Use a drain snake and really clean the drain out.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
ed marsh estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 12
Todo El Tiempo: 320
