Saltar al contenido principal
This laptop was released in late 2015 and came running Windows 10 Home. It features a touch screen display, Intel i5 processor, and a 1 TB hard drive.
Preguntas 3 Ver todo
seems to have a defective power port.
It seems the power port is defective. I have tested the charger on another laptop and purchased a new battery that works, so have to assume it’s the port. Is it part of the motherboard or a separate item?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Hi @edwardw10 ,
Here’s a link to the hardware maintenance manual for a HP Pavilion 15-ab243cl laptop, taken from this webpage
Scroll to p.69 to view the necessary pre-requisite steps and then the procedure to remove / replace the Power connector cable.
Disconnect the cable from the motherboard and then use an Ohmmeter to check the wires for continuity from the socket through to the cable connector plug.
If it is determined that the cable is faulty then you’ll find the spare part numbers at the top of the same page in the manual.
Search online using the part number only to find suppliers of the part.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Edward Wilman estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 7
Ultimos 30 días: 14
Todo El Tiempo: 140
