Saltar al contenido principal
Soporte para la serie CQ57 de ordenadores portátiles Compaq.
Preguntas 38 Ver todo
Why is screen totally black after turning on but capslock light is on?
When I switch on my laptop the screen is totally black. I have tried to fix by removing the battery and pressing the power button for 30 seconds but hasn't fix it. Please help me to fix this.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
connect a external monitor and check if you are getting anything on the display
Fue útil esta respuesta?
Puntuación 0
This is usually loose RAM on an HP, or in some cases a failed module. Remove the battery, the main cover below the hard drive cover and reseat the SODIMM module/s. If it persists, they're bad and need to be replaced.
If neither of these help, the motherboard is dead - common on these "low cost" HP laptops.
Puntuación 0
Añadir tu respuesta
Komal Agarwal estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 102
