Saltar al contenido principal
El Kenwood Chef A701A es una batería de pie lanzada por Kenwood.
Preguntas 49 Ver todo
Why is the mixer tripping the electricity out and can it be repaired
When plug in and attempt to switch on the electricity trips at the box taking out all sockets in the house. What is likely to be wrong and can it be repaired
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Unplug it, open it up and look for where it’s burned. You have probably pulled a wire loose and it’s totally shorted out.
Kenwood Chef A701A Power Cable Replacement
Fue útil esta respuesta?
Puntuación 1
Hi,
Most probably it can be repaired.
There is a short circuit connection in the mixer somewhere that is causing the breaker to trip when the mixer’s switch is operated.
It could be a faulty component such as a capacitor being short circuit, an internal wire touching the frame of the mixer or maybe even the switch itself shorting out to the frame.
Here’s an image of the wiring for the mixer taken from the service manual. The manual has full dismantling instructions for the mixer starting on p.3.
With the mixer totally disconnected from the power, use a DMM’s (digital multimeter)-Ohmmeter function, in conjunction with the circuit diagram to test where the short circuit is in the mixer’s operating circuit.
Once you have identified the problem then if it is a component that is faulty the manual has a full parts list which will help in getting the replacement part or hopefully an equivalent part if it is not available.
If you don’t have a DMM or know how to use it or know how to read a circuit diagram then perhaps you may know someone who can do this for you.
If not then contact a reputable, professional electronics or appliance repair service and ask for a quote. Tell them about the service manual being available online as it will help them if they are unfamiliar with the mixer.
(click on image to enlarge for better viewing)
Hopefully this is of some help
Puntuación 1
Añadir tu respuesta
hesketh.ram estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 19
Ultimos 30 días: 132
Todo El Tiempo: 10,938
