No display when tried to upgrade cpu in laptop
Upgraded my i3 330m to i5 560m and there is no display but hard drive and fans works and caps lock blinks……
But again had to switch to i3 and it works fine…..
I hv not tried to remove CMOS battery during upgrade to reset the bios, can this step solve the issue
Es esta una buena pregunta?
1 comentario
Hi,
What is the full model number of the laptop?
Try connecting an external monitor to the laptop and check if it has a display at all. Remember to press F4 to toggle between the displays i.e. laptop only, external only and both on together.
If your laptop has a HDMI port even a TV can be used as an external monitor as long as it has a HDMI input and you have an appropriate HDMI cable to connect the two together.
- de jayeff
