Erratic charging and restarts after sound ic repair
Guys im lost here. I have done a lot of iPhone 7 and 7+ sound ic, guessing around 100, the thing is, for some, the following happens
1 iPhone will boot normally, albeit a little slower.
2. Sound that was not working before works perfectly
3. It does not charge properly, it starts ok at normal amps then drops to 0, the battery % jumps after every reboot and sometimes when the iPhone is being used.
4. The battery shows as maintenance, with no health meter, the battery before had like 90% health.
5. I have tried new charger, new battery, turned it on off the hosing, redone the sound ic fix 4 times and still same problem.
6. I have had this problem like 5 times and one time it solved itself when I put all these screws etc back. Others when I redid the sound ic
Any help to what the !&&* is going on will help a lot guys, thanks for you're time.
Update (01/27/2020)
SOLVED!! It was the battery connector, i removed the plastic middle part exposing the two metal connectors for SWI, added some solder also and it worked perfectly! hope this helps other that may have this issue.
Es esta una buena pregunta?
2 comentarios
Still the problem persists guys… if anyone can help would be great….
- de danbedin
Its time to look at charging circuit than. Tigris, Tristar and charging fet.
- de Chris Stables
