Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Primera generación de iPad de Apple con capacidades 3G. Número de modelo A1337. Disponible con 16, 32 o 64 GB de almacenamiento. Las reparaciones son sencillas y no requieren calor.
How to replace SIM module?
Hi Guys,
I tried to replace a SIM Module for iPad 1 Gen, but it can't find the 3G signal yet, I would like to know whether the logic board locks the module while replacing the modules or not, if yes, how to unlock it?
Thanks a lot.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
I would bet the IMEI was blocked somehow or the antenna is bad
Check the IMEI, if it is blocked, the only legal way to fix it is to swap the logicboard(I would suggest changing it, but it turns out it's not legal, even if it is done as a personal fix and you aren't selling your device, DO NOT DO THAT!)
By all means if it isn't, the 3G antenna could be bad, change that
If it still doesn't help, your only hope is a logicboard(legalities changing the IMEI)
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
apple5808 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 1,254
