Saltar al contenido principal
The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
Preguntas 120 Ver todo
Can not get off safe mode
After my Samsung Tab A died I put it on charge and turned it on so I could use it while it charged. It wss on safe mode disabling all my apps. I noticed my volume buttons ate stuck and I can't use them. Why is this? Is there any other way of getting out of Safe Mode?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi,
The Volume buttons may be jammed.
The Volume Down button being jammed operated causes the tablet to go into safe mode when you start it.
As you can see from the procedure to enter safe mode in your model:
Turn the device off.
Press and hold the  Power key.
When 'Samsung' appears on the screen, release the Power key. Immediately after releasing the Power key, press and hold the  Volume down  key.
Continue to hold the Volume down key until the device finishes restarting.
‘Safe mode' will display in the bottom left corner of the screen. Release the Volume down key when you see 'Safe Mode.'
It may be that you will have to open the tablet and find out why the Volume buttons are jammed.
Here’s a link to the ifixit Samsung Galaxy Tab 3 7.0 guides. They should be of some help in opening the tablet to determine why the buttons are jammed.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
leannebeadle estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 548
