Saltar al contenido principal
El teléfono insignia de Samsung con stylus y el sucesor del Note8, lanzado en agosto de 2018. Cuenta con una pantalla de 6.4 "y hasta 512 GB de almacenamiento a bordo.
Preguntas 104 Ver todo
Note 9 wont turn on. Left on 0% charge
Hello, I have note 9 sm n960u and its not turning on completely dead. No light no vibration nothing. I have tried all troubleshooting steps tried many different cable wireless chargers and everything i possibly could so to fix it but it wont respond. As this device was bought in US and i am not in US any more so i cant send it to service center so i went to a local repair shop and the guy there told me thats its the board dead. Now i have no idea what to do as the device was running perfectly when i kept it aside after complete discharge. I would be glad if anyone can help me with hardware based trouble shooting. I still havent tried new battery as the guy told be thats its with motherboard so should i trust him or try a new battery? Is there any way i can check shortage with multimeter to confirm myself? I would be happpy if someone help me out witht this
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
4 comentarios:
are you using the original charger or a Fast Charger that goes up to 9V, 2AMPs?
- de
@conlledo yes i am.
- de
Any one has this problem or its only me?
- de
I replaced battery and charging port still charging but won't charge beyond 0%. When I changed battery it started with a small amount of charge. Left it on charger to charge to 100%. Returned to it after an hour to check progress and it was not showing percentage. Refused to charge and now stays at 0% even in safe mode.
- de
Agregar un comentario
1 Respuesta
@mustaqeem the instructions from My battery died to 0% and won't charge now, wired nor wireless. would only work if your battery was discharged below its charging threshold. It will not fix a battery. My suggestion would be that you start with a new battery. Your battery may have shown a proper voltage but may not accept a load or fail under a load. Replacing the battery will at least give you a known well starting point should further troubleshooting be needed. Check this teardown Desmontaje del Galaxy Note9 to see what is involved with that.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Mustaqeem estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 21
Ultimos 30 días: 50
Todo El Tiempo: 3,009
