My camera wont stay on.
The camera comes on, the green light on the back flashes once. The lense starts to come out, then immediately retracts followed by 3 beeps.
Es esta una buena pregunta?
First, a easy fix, charge the battery overnight, put it in, power it up, if you yield the same result, replace the battery and see what happens
I will update this after we have more details on what happens and what you did to troubleshoot
Fue útil esta respuesta?
I think the answer is in the question Read the second sentence carefully....
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 1,689
6 comentarios
I go with a stuck lens. It can cause errors the way you described yours. Check on here for more info
- de oldturkey03
I'd agree with oldturkey, it's a good link too
- de pollytintop
Hi there
I'm sure you have problem with lens of camera . is not that eays to be fix by ur self if you don't have exprince on repair camera but you can try .
you have to know some time after fix it stil you have problem that is u can see line on you lcd screen . is mean you have change your lens .
I do repair cameras .
- de cyrus
Hi there
I think you had problem with lens Of your camera ./ maybe you dropprd your camera.
cyrus_7029@yahoo.com
- de cyrus
I seem to be having the same fault with my Samsung L100 camera. I fitted a replacement battery and still the same fault is present
- de Sean
Mostrar 1 comentario más
