What size belts does this use? (Sears 560.21674350)
I picked this up on eBay to have a descent small tape deck (I am aware it isn’t audiophile grade, but a lot of these older dictation decks are far better then the modern Type I record only ones) and I already know the belts will probably be trashed based on how old the unit is.
The thing is I do not know how big of a belt I need to get the unit going with fresh belts so I do not need to worry about the 25+ year old belts going bad. Does anyone know if this uses a common belt I can get in a set or do I need to look for a specific belt listing? Being a Sears deck (the capstan length looks right to me so it’s not one of the nonstandard ones they rigged. Being computer compatible also helps.) I suspect it’s a pretty standard spec belt I can get cheaply.
Es esta una buena pregunta?
