locate park light relay f-250
2003f 250 where is park light relay located?
Es esta una buena pregunta?
Hi @shosteen
The owner manual for your model vehicle doesn’t show a relay for the parking lights but it has got a fuse for the exterior lamps.
Check if fuse #17 in the passenger compartment fuse panel is OK.
Here’s an image taken from the manual that shows the location of the fuse
(click on image to enlarge for better viewing)
Fue útil esta respuesta?
Light switches are always burning if you dont find the problem elsewhere, open up the light switch and inspect for black spots.
Check wires at door jam inside rubber boot cracked shorting out
Relay is behind radio along with trnsignal flasher
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 80
Todo El Tiempo: 2,174
