Essick Pedestal Humidifier Broken Caster Repair
I have an Essick Pedestal Humidifier and one of the casters got broken. I looked at the bottom and it looks like the plastic that houses the caster's leg part is broken and the broken plastic piece is still on the caster's leg. How do I put it back together and make it strong? The humidifier gets about 4 gallons of water when it's in use and itself is another 10 lbs so it needs to be strong enough to carry a load of 40 lbs or so. What material should I use and how should I put it back together. Pls see the pictures. Thank you all in advance for your suggestions.
Es esta una buena pregunta?
