Saltar al contenido principal
Cámara SLR de enfoque manual de 35 mm fácil de usar. Número de modelo X-370.
Preguntas 25 Ver todo
I can’t see through the viewfinder?
I bought my minolta x-370 online. when i got it, i could see through the viewfinder but the lever was stuck so i figured it needed new batteries. i got new batteries for it, put them in, and i tried to take a picture but something happened and now i can’t see through the viewfinder and the lever is still stuck.
does anyone know why this is happening? is something broken?
Update (11/03/2019)
I could see through the viewfinder just fine before I added new batteries. Now all I can see is black and the mirror won’t stay down.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios
Take the lens off do you see the reflex mirror up or down?
- de
the mirror is up @danj
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Carefully pull on the mirrors edge ever so slightly! To test to see if the foam cushion got gummy which is now holding the mirror. Don’t pull more than a millimeter or two as you could damage the mirror linkage.
If that don’t do it you’ll need to find a camera repair person who has the skills to pull the mirror cage as the linkage or the electromagnet has a problem. This is more than a DIY job.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
hayley louis estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 988
