Slow to no charge, Overheats
Recently replaced battery, lightning charge port and screen with iFix parts and guides. Phone is charging slowly, won’t hold a charge and is hot to touch.
Es esta una buena pregunta?
You may have a partial short in one of the circuits from the drop that caused the screen to crack that’s why it is getting hot and not holding a charge. If you haven’t got the equipment or know how it would be best to get it looked at by a repairer. To avoid more damage I would stop using it until it has been fixed.
Fue útil esta respuesta?
Screen crack to death was 9 months.
Hi Lloyd charging slowly, won’t hold a charge and is hot to touch equals a short somewhere on the logic board. Maybe on the charging circuit.
@imicrosoldering IC chip? I’m not confident in my soldering skills to attempt that fix. Need to find a local.
Yes find a local repairer. They would check VVD main and VDD boost circuit; it might only be a cap on those lines that is faulty. If not the charging circuit would be next. Most repairers have a Tristar tester which they would use to check the charging circuit.
@imicrosoldering Are there videos on how to test the VVD main/boost circuits. While I'm not yet confident to fix this I would very much like to learn. And what is/where does one get a Tristar tester? BTW, thanks for all the info you've been a great help.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 330
2 comentarios
@lloydgodin what made you replace all of those parts? What did your phone do before you replaced them?
- de oldturkey03
Screen was cracked. It wouldn’t charge or turn at all despite having plugged in, cleaned port, holding power button and volume down. Was 100% dead
- de Lloyd Godin
