Saltar al contenido principal
Released in October 2015. Model number: 80NV00D5PB
Preguntas 11 Ver todo
How do I clean my keyboard internally?
I spilled some col drink on my Laptop, I want to clean it up since I am getting weird issues with my keyboard.
I tried to open it up but it seems to be stuck in some way. So I wasn't sure if would be able to close it back. Also I dont want to mess my processor by removing heatsink or something since I have never done it before.
I really appreciate you helping me out, thank you!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @zedkasat
Here’s a link to the Hardware maintenance manual for your laptop, taken from this webpage.
The keyboard is part of the uppercase assembly.
Scroll to p.55 to view the necessary pre-requisite steps and then the procedure to remove the assembly.
Usually when attempting to clean/repair keyboards you can introduce more problems than what you originally had. It is better to replace the keyboard or in this case the upper case assembly. On p.76-77 Item #2 you’ll find the country specific upper case part numbers.
Usually the part number is to be found on the underside of the assembly somewhere if you wish to verify that you have the correct number.
Once you have found the part number appropriate for your particular model variant, search online using the part number only in the search term of your browser to find suppliers of the part.
Hopefully this is of some help.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Siddhanth estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 1,263
