Problem booting up Xiaomi Mi Max 2
Hi all, So the phone does not turn on or show any sign of life while unplugged, not even the notification led lights up.
- When i plug it in, the "mi" logo appears for a second and then it turns off.
- When i try booting it into recovery mode (while plugged in), the "mi" logo appears, phone vibrates and then it turns off.
- When i try entering fastboot while plugged into the outlet, fastboot appears for a second, screen goes black but the notification led keeps blinking.
- When i try entering fastboot while connected to the PC, fastboot screen appears for at least 30 seconds, USB malfunctions and the device is not recognized (Trying MiFlash tool latest version.)
- I also tried using several other chargers and a power bank, It usually draws power for a minute or so as though it's charging and then it stops.
The cause of this issue is most likely water damage (The phone is in a pristine condition, never been dropped or mechanically damaged).
So what could be wrong with the phone and what could i do to fix it?
Any thoughts or comments are appreciated.
Es esta una buena pregunta?
3 comentarios
i have same problem it screen got damage due to large size i change it again this happen
- de Nitya Nair
It's from the battery most probably, I changed mine and it was fixed and booted up.
- de 7skies
@Nitya Nair ?
- de 7skies
