Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Kenmore 110 Series es una lavadora para el hogar de fácil uso creada por Kenmore.
Why is my Kenmore washer making loud noise during spin cycle?
I have a 5 year old Kenmore washer model 110.27102310 that has started making a very loud noise during the spin cycle.
The noise becomes louder at high spin speeds and sounds similar to that of an  aircraft with a propeller.
Would this sound be caused by the drum bearing going bad or another component?
Es esta una buena pregunta?
Puntuación 0
1 comentario
Did you get this solved? Have same model and similar jet noise problem
- de
Agregar un comentario
1 Respuesta
Solución Elegida
If your Kenmore 110 Series Washing Machine is making strange noises, see the Kenmore 110 Series Washing Machine Makes Unusual Noises problem page for possible causes and solutions.
Check to see if you have a model descriptor something like a VMW etc. so we can check to see if there is a diagnostic program you can run. Yes, the tub bearing is a definite possibility. There are a few more things to check. things like:
bad transmission
worn out pulley
worn clutch lining
Fue útil esta respuesta?
Puntuación 3
1 comentario:
The Kenmore washer did display an error code in diagnostics mode.
The Error Code I read was F7 E6, which indicates a Motor fault.
So, It appears that I may have to replace the drive motor.
- de
Añadir tu respuesta
Dave estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 25
Todo El Tiempo: 1,369
