My adapter is broken on my speaker
The yellow part where you charge the Sony SRS-X55 is broken. How can I replace this?
Es esta una buena pregunta?
Darla Dang that is your DC in jack. It is soldered to the I/O board. Remove that board by using this guide Then check if you can unsolder it and find a replacement based on the dimension from places like mouser. com or digikey.com etc. Not a terrible complicated repair but it does require some soldering skills.
You can get the jack connectors from here https://ru.aliexpress.com/item/202656625...
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 410
