Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Kenmore 110 Series es una lavadora para el hogar de fácil uso creada por Kenmore.
Kenmore Washer Spin cycle noise
My 5 year old Kenmore washer model 110.27102310 has started making a very loud noise during the spin cycle.
The noise becomes louder at high spin speeds and sounds similar to that of an  aircraft with a propeller.
Would this sound be caused by the drum bearing going bad or another component?
Thank you,
Dave
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
If your Kenmore 110 Series Washing Machine is making strange noises, see the Kenmore 110 Series Washing Machine Makes Unusual Noises problem page for possible causes and solutions.
Check to see if you have a model descriptor something like a VMW etc. so we can check to see if there is a diagnostic program you can run. Yes, the tub bearing is a definite possibility. There are a few more things to check. things like:
bad transmission
worn out pulley
worn clutch lining
Fue útil esta respuesta?
Puntuación 3
1 comentario:
The Kenmore washer did display an error code in diagnostics mode.
The Error Code I read was F7 E6, which indicates a Motor fault.
So, It appears that I may have to replace the drive motor.
- de
Añadir tu respuesta
Dave estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 26
Todo El Tiempo: 634
