Saltar al contenido principal
Wi-Fi única variante de la quinta generación de iPad, lanzado en marzo de 2017. Disponible con opciones de almacenamiento de 32 y 128 GB con una pantalla Retina de 9,7 "y un procesador A9 de 64 bits.
Preguntas 93 Ver todo
iPad is disabled connect to itunes on MacOS Catalina
Hi, I have a ipad with error message “iPad is disabled connect to itunes” but itunes is no more available on MacOS Catalina !
Can somebody please help me to restore this ipad ?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 8
1 comentario
No one has yet found an answer. Apple sure stuffed getting ipad back alive
- de
Agregar un comentario
7 Respuestas
Respuesta Más Útil
Check this out, it is still possible to restore an iDevice on Mac OS Catalina:
https://www.imore.com/how-sync-your-ipho...
Fue útil esta respuesta?
Puntuación 3
Hi, Thank you for your answers ;-)
I finally found the solution. iPad was managed by “apple configurator 2”, so I started the iPad in recovery mode and connect to “configurator 2”. Then click on “recovery”.
Best regards
Puntuación 2
1 comentario:
Thank you so much! This did the trick. I downloaded the configurator and clicked around with update (I believe I had to restart the iPad once to get the process going). It installed a new operating system.
- de
hey! did u find out?? im having the same problem rn and i don’t know what to do lol
Puntuación 0
This is the official article on how to fix what you’re experiencing:
https://support.apple.com/en-us/HT204306
Puntuación 0
1 comentario:
it didn't work :(
- de
You know what? I read an article about this exact same problem!
So here is it: iPad is disabled connect to iPad
Basically, you hook up your iPad with your mac, and you will see a notification telling you to restore the iPad.
If not, the easiest solution is to use Joyoshare iPad System Recovery to restore the iPad without data loss.
Puntuación 0
Resetting the ipad can be done using the Finder on Mac OS Catalina.
  1. turn off iPad and unplug from Mac
  2. start Finder
  3. press Home button
  4. plug iPad in while Home button is pressed
  5. iTunes logo will appear on the iPad
  6. iPad will appear in Finder
  7. a prompt to update or reset to factory settings will appear on the Finder.
  8. Follow on screen instructions to update or reset the iPad
This video demonstrates this process.
Puntuación 0
if you have a separate device like windows you can use iTunes from there, or upgrade to a newer version of mac os
Puntuación 0
Añadir tu respuesta
Guy Lerou estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 8,169
