Saltar al contenido principal
Laptop 7000 de 15" diseñado para una elegancia compacta. El diseño liviano presenta un bisel ultradelgado y bordes con corte de diamante para un estilo más nítido.
Preguntas 2 Ver todo
Potentially ominous problem discovered under hood of Inspiron 7570
I just removed the casing for a first time battery change after 18 months since I bought this device, and discovered that the foil on the hard drive is split, with a connector peeking out. In all other images/videos for this model, the foil is intact and no connector is visible. Can anyone explain what might have happened here? Thanks
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
You bought a machine that just came with an SSD and Dell included the cable and drive caddy so one can be added later. You didn’t get screws, but 2.5” drive screws aren’t hard to get.
Think of it like this: Your machine didn’t come with a drive, but it was provisioned so you can add one.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
You've really put my mind at rest. Thank you Nick.
- de
Añadir tu respuesta
Steve estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 284
