Saltar al contenido principal
La Pathfinder de segunda generación se introdujo a fines de 1995 con un estilo más redondeado. Fue completamente rediseñado desde la primera generación, pasando de la construcción del cuerpo en el marco a la construcción de un cuerpo.
Preguntas 17 Ver todo
My pathfinder turns over but wont start
It will turn over but won't start. It is getting fuel and sparking. I just had the exhaust repaired. It ran for a few minutes but when I started it up again it shut off and won't start back.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios:
What was the exhaust repair?
- de
Not a gear-head here, but a quick search for common culprits gave me this rather detailed troubleshooting overview:
https://shop.advanceautoparts.com/r/car-...
Some further digging suggests that, if it isn't the common reasons then it could be a failed camshaft or crankshaft position sensor
- de
Agregar un comentario
2 Respuestas
My suggestion would be to replace the fuel filter. Maybe some sediment in the gas tank got sucked into the filter when you ran the vehicle on low fuel. This sounds like a textbook issue of a clogged fuel filter.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Jessica the OP stated that " It is getting fuel and sparking." How would that correspond with a clogged fuel filter?
- de
When you work on your car and it does not work after you are finished, you broke something in the area where you was working, the crank position sensor CKP is probably near the back side of the engine, I would guess that a wire is broken in the exhaust area where you was working, do a very good inspection.
Puntuación 0
Añadir tu respuesta
heathernkelly0126 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 1,778
