Saltar al contenido principal
The first generation Nvidia Shield Tablet released in July 2014. This device is often used for gaming, and has Wi-Fi and LTE capabilities.
Preguntas 23 Ver todo
I wiped my hard drive by mistake
would that get me access to the tablet again ? currently i cant access it as i wiped it and cant recover it. Or will replacing the mother board do nothing and put me in the same boat im currently in now -with having to reinstall the OS ?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
4 comentarios:
is the recovery partition still on the device?
- de
no sadly i wiped it :(
- de
Yes by replacing it you be running again
- de
My next question is replace the motherboard or trying to flash the current one that has been wiped ? I mean there must be a way to flash it..no? They do it at the plant I literally have a clean slate hd/motherboard there must be a way to flash it ...if I can't is the original Motjerboard 2015 shield the same is the shield k1 version circa 2017
- de
Agregar un comentario
1 Respuesta
Start with this in fastboot mode:
https://twrp.me/nvidia/nvidiahshieldtabl...
Flash the TWRP - then you can search XDA to get a ROM to flash https://forum.xda-developers.com/shield-...
https://wiki.lineageos.org/devices/shiel...
Recovery: With the device powered off, hold Volume Down and tap Power, then release once menu is displayed. Tap Volume Down until recovery is selected. Press Power to select.
Download: With the device powered off, hold Volume Down and tap Power, then release once menu is displayed.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Andrew Brown estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 140
